NI TestStand
TestStand Error calling LabVIEW VI
I have a simple TestStand sequence executing some basic LabVIEW VIs in batch model.  One step in the sequence throws an error, code -17308, "specified value does not have the expected type".  I search on the NI forum and on Google, but cannot find the explanation for the error. I attach here the zip file which contains my sequence, the LabVIEW VI and the error message popup.
(2,757 Views)
My guess is that StationGlobals.U2653A_Channel is not an array of numbers.  Is it an array of strings?  What is it?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,727 Views)
Accepted by Nelson19
No. It is not.  Anyway, I made changes and the error went away.
(2,662 Views)
