NI TestStand
TestStand IVI Read Numeric Limit Test
Hey all,
How can I turn a IVI DMM reading into a test step pass / fail based on a numeric limit test?
I'm a TestStand newbie so be gentle.  Searches on the forum for TestStand IVI and pass fail don't return anything useful.
I can call the DMM via IVI Read wich returns a Step.Result.Reading value but I need to turn this into a pass fail on a limit range.
Any ideas would be very gratefully appreciated.
(3,506 Views)
Accepted by tadders
You could insert an none_adapter numeric limit step after it and set the data source to PreviousStep.Result.Reading.
-Doug
(3,499 Views)
Just the ticket!
Thanks Doug
(3,481 Views)
