TestStand MCP beta
I’m planning to release a TestStand MCP in the next days. It is almost fully functional, so the main features are already working. Is anyone interested in becoming a beta tester?
"mcpServers": {
  "teststand": {
    "command": "C:\\Projects\\TestStandMcp\\TestStandMCP.exe",
    "args": []
Best
Claude
Btw.: NI should be able to implement this using the TestStand source code within a few days. I had to implement it using API calls that aren’t particularly well documented!
CLA / CTD
(312 Views)
How is this going to be different from NigelAI integration in TestStand?
Santhosh
Soliton Technologies
(291 Views)
You can use it directly from the strongest AI tools available on the market (Anthropic Claude, GitHub Copilot ....). You can directly generate test sequences from flowcharts and so on... 🙂
CLA / CTD
(273 Views)
For example you can Generate from a Picture or PlantUML or whatever Flowchart Sequences:
You can also generate Flowcharts from Sequences:
My MCP is almost complete. I'm currently working on the implementation style guide...
CLA / CTD
(247 Views)
Hi, looks cool. I would be interested in checking out what it can do 🙂
(85 Views)
I am currently preparing the code for an official release. I will share the link as soon as everything is ready.
CLA / CTD
(74 Views)
Here is the first version of TestStand MCP Beta_V0.0.1:
https://github.com/Zuehlke/teststand-mcp
https://github.com/Zuehlke/teststand-mcp/tags
Best Claude
CLA / CTD
(30 Views)
