TestStand Message Popup
How to display the message expression such that it reads the local variable value?
For example:
Locals.Index = 5
Message popUp should display:
" The current Index is = 5"
Where 5 <or value> is read from Locals.Index.
TIA.
CLD
(5,565 Views)
Accepted by lvrat
Hi  Ivrat,
Just take a look on the attached Example
Hope it helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,560 Views)
" The current Index is = " + Str(Locals.Index)
(5,548 Views)
Thanks. Sorry for the stupid ?. Answer was even simpler than the example you posted. I am learning, Slowwwwwww.
(5,310 Views)
