NI TestStand
TestStand Numeric Multiple Limit Test Data Logging to SQL Database using Stored Procedures
We are receiving a foreign key constraint error when attempting to log the result of a multiple numeric limit test to a SQL Server database. Any suggestions?
CLA
(2,351 Views)
I think it is a bug in the actual logger. I can go into the database and add a new row to the STEP_NUMERICLIMIT2. As long as the value in the PROP_RESULT field exists in STEP_NUMERICLIMIT1 then the row can be added. If it does not, I get the same error message that TestStand gives me.
CLA
(2,330 Views)
Hi terckson,
Thanks for reaching out. Sorry you're having issues. It's not totally clear what's going on right now. Could you narrow down the issue to a specific log, or data type that you are sending to the server? Does it happen every time, or just some times? If you log just a single data point to your database, does the same error throw?
Thanks in advance.
Keddy C.
Staff Software Engineer
(2,309 Views)
