TestStand ProcessedResults and UnprocessedResults directories
There are a couple of directories in "C:\Users\Public\Documents\National Instruments\TestStand 2013\Components\Models":
ProcessedResults
UnprocessedResults
TestStand Results.mdb
What is their function? On one station I administer the size of the ProcessedResults is 9 GB. This large size makes software updates very slow.
(2,714 Views)
Accepted by stephenb2
The ProcessedResults and UnprocessedResults are the default outbox & inbox for the TestStand Offline Results Processing Utility. There are settings in that utility to automatically delete processed files under a variety of conditions. You can also configure the settings for generating offline results in TestStand under the Configure » Result Processing menu.
TestStand Results.mdb is just an example access database.
Hope this helps!
Trent
(2,700 Views)
It does help, thanks!
(2,687 Views)
