NI TestStand
TestStand Request for SCC Integration
One thing about TestStand that really gets on my nerves is that you cannot choose "edit vi" from the menu when a sequence attribute is set to read only.  I know it seems like the right thing to do, but all edit vi does is open the vi so you can look at the code.  Instead of being able to open it quickly and debug I am forced to either check out the sequence file, search for the file in the workspace or on the harddrive, or manually set the sequence read only flag to read\write.  I don't think that the edit vi menu selection should call the "do you want to check out the sequence" prompt.
(3,083 Views)
Scott Richardson
https://testeract.com
(3,070 Views)
The allow editing of read-only files flag helps.  I did not know about that flag.  Thanks for the work around.
(3,056 Views)
