NI TestStand
Link the Test Stand UUT serial number with a labview VI
I wish to use the Test Stand UUT input serial number in one of the labview VI's within my sequence so that I can output some figures to a spreadsheet and relate them to the UUT serial number. Is there a way of linking the 2 together???
Chris
(see example attached)
(5,947 Views)
Accepted by topic author beam7
You can get your serial number by using the following lookup string "RunState.Caller.Locals.UUT.SerialNumber"
There is an example at the following link:
http://forums.ni.com/ni/board/message?board.id=330&message.id=6938&query.id=198397#M6938
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(5,930 Views)
Thanks, that works great...
(5,919 Views)
