NI TestStand
execute bat in teststand
Hi users,
Situation:
I call from Teststand 4.1 a bat.file that executes a programming software  (FLink.exe) with the corresponding jtag Hardware (RLink from ST Microelectronics), to programm a µController on my testobject.
Problem:
the bat file ist executed, but the µController can´t be programmed,because of en errror message of the flink!. But when I call the bat from the explorer it works properly.
Has someone experience with such a kind of problem?
I would be pleased about an solution.
Grettings
Michael
Greetings Michael
(6,537 Views)
Does the batch file assume that the working directory is the same as the batch file?  This might be what is happening.  Go to the <TestStand>\Bin\ directory in a command prompt.  Type the full path to your batch file and run it.  You will likely see the same behavior you are seeing from TestStand.
(6,528 Views)
Accepted by topic author muemi
I found a solution to my problem with the help of an engineer by NI!
I had to change the active directory to the directory were my working Batch-File is executed!
see related links:
http://digital.ni.com/public.nsf/allkb/D0F75B559DB622B586256BBF007A1B64?OpenDocument
http://digital.ni.com/public.nsf/websearch/365DC2996F67D8AF86256AF000558B90?OpenDocument
Greetings Michael
(6,511 Views)
