NI TestStand
TestStand Runtime
there exist the possibility to download and install only the TestStand RunTime Engine? I cannot find it...
Thank you in davance
(1,946 Views)
Hi fgalluzzo
Did you try to download it from NI Package Manager?
Regards)
(1,731 Views)
The TestStand runtime is not published as a separate download on ni.com. If you download the offline TestStand installer (*.iso) from ni.com and mount the file, you will see that there is an \AdditionalInstallers\ subdirectory that contains a "Runtime32" and a "Runtime64" directory which corresponds to the two bitnesses of the TestStand runtime.
Scott Richardson
https://testeract.com
(1,718 Views)
