06-11-2008 09:57 PM
06-13-2008 02:00 PM
Tim -
The information that would be useful is:
It might be helpful if you exported your schema to an ini file and shared the file with us.
02-09-2012 01:07 PM
02-09-2012 01:11 PM
I am getting a similar error trying to log data to a SQL Server 2008 database. The issue seems to happen when a numeric type DBL is reported as 'INF' by TestStand.
I am using TestStand 3.5, LabVIEW 8.2 & SQL Server 2008.
The complete error message I get is as follows:
-2147217900; User-defined error code.
An error occurred calling 'LogResults' in 'ITSDBLog' of 'DBLog 1.0 Type Library'
An error occurred executing a statement.
Schema: Rev01 Drager SQL Server Stored Proc.
Statement: STEP_NUMERICLIMIT.
The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 9 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision.
Description: The incoming tabular data stream (TDS) remote procedure call (RPC) protocol stream is incorrect. Parameter 9 (""): The supplied value is not a valid instance of data type float. Check the source data for invalid values. An example of an invalid value is data of numeric type with scale greater than precision.
Number: -2147217900
NativeError: 8023
SQLState: 42000
Reported by: Microsoft OLE DB Provider for SQL Server
Source: TSDBLog
Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Has anyone seen this before???
pete
02-10-2012 11:58 AM
Hi plf,
I believe you may have a conflict between the TestStand type that you are trying to write and the database type that you have chosen. What value is your database expecting?
http://digital.ni.com/public.nsf/allkb/D9D351C8D566078286256BCF00676E9F?OpenDocument
Michael Miracle
NI Americas | AE
