NI TestStand
TestStand Seq Editor appears during application install/uninstall
I'm using the TestStand 3.1 Deployment and when I install (uninstall) my application on the target, before it gets to the finish step, the TestStand Sequence Editor appears. I have to click cancel, then File::Exit. Then I can click Finish to complete the process and reboot. I thought I might have selected "Create Program Item" in the Installer Properties of the Distributed Files tab, but no. I'd like that annoying behavior to stop. Any ideas?
(3,368 Views)
One option that I recommend is simply do not install the sequence editor on your deployment machine. In most situations, TestStand sequences are run from an operator interface on deployment machines so the sequence editor is usually not necessary.
To not include the TestStand sequence editor, go to the Installer Options tab of the TestStand Deployment Utility and click on the Engine Options button. Once there, you should see a check box to include the sequence editor under the Development System section. I would make sure the check box for the sequence editor is not selected.
I hope that this information helps you out.
Kevin L.
(3,356 Views)
The only thing I have checked in the engine options is 'engine'.
(3,349 Views)
Kevin,
I was in error when I said the Sequence Editor comes up. It is just the TestStand Operator Interface that comes up.
(3,346 Views)
Hi Mrbean,
In the TestStand deployment Utility under the Distributed Files tab, click on your Operator Interface. You will find a checkbox called "Register as ActiveX Server" right above the "Create Program Item" box. You have this box checked, so unchecking this should solve your issue.
Hope this helps!
SijinK
(3,329 Views)
