NI TestStand
What does error 17502 indicate?
When I run my TestStand Sequence, I'm receiving the following error code "-17502: System Level Exception". The step that fails is a call to a DLL and the sytax of the call looks correct. I call the same DLL various other times before the failed call, and those work fine. When I look up the error code in your supplied help, it is only described as a TS_ERR_OS_Exception.
I have been stuck on this problem for a few days and don't know what else to try. Can you possibly give me any insight into what could possibly be causing this error?
Thank you, I really appreciate your help.
Michael
(4,860 Views)
Hi Mike,
Some the response from Anand on this message maybe helpful.
Have you tried stepping into the code?
Regards
Ray Farmer
Regards
Ray Farmer
(4,851 Views)
