TestStand and LabVIEW share functional global variables
I build a functional global variables in a LabVIEW project, and I use it both in VIs and TS sequence files correctly.  However, when I generate a EXE from VIs, the functional global variables don't work well in the TS sequence. How can I deal with it?
(3,254 Views)
@GrayJoker wrote:
[...]  However, when I generate a EXE from VIs, the functional global variables don't work well in the TS sequence. How can I deal with it?
Brutal answer: Do not use global data storage.
The reason is that the global variable you are using from TS is (presumably) still a "stand-alone" global while the EXE uses an internal one. More details can be found when digging into the topic "Application Instance" in LabVIEW.
I strongly recommend to use parameters to pass data between TS, code modules and the UI and NOT using global data structures.
(The alternative to rewriting stuff would be configuration of the LV adapter in TS to use your EXE as runtime environment for LV which requires your EXE to provide an ActiveX interface. This is presumably equal amount of work compared to implement a proper solution.)
Norbert
Expert: Geometry
(3,234 Views)
Or compile the globals into a Packed Project Library and make sure you are only calling the PPL globals.
GCentral
(3,231 Views)
Did you test this? It still can lead to two different global VIs in memory in different application instances.... (i assume at least)
Norbert
Expert: Geometry
(3,227 Views)
