NI TestStand
TestStand and MFC42.dll
Hello everybody !!
I've a real hard problem with TestStand and a DLL which is a MFC DLL. So, an error occurs irregularly but only when TestStand has already loaded a DLL using MFC. But this error does not occur each time, that's what is rare. When this error appears, a TestStand window is launched, and explains there is an error with MFC42.dll.
Is there someone to help me ?
(3,008 Views)
From what you describe, it seems that the problem comes from the DLL. If you have the source code of the DLL that use the MFC DLL, it would be useful to debug it.
We are not aware of such issues with TestStand, but if you need help please provide us more data, like : the error code or error message, the OS, the versions of the software, etc.
(2,957 Views)
