NI TestStand
show report in SequenceEditor when using no process model
(3,103 Views)
Basically you would have to do the sort of tasks the process model does in you sequences.
At a minimum you can call TS API Report.Append method to write a string to the Report Window.
Regards
Ray Farmer
Regards
Ray Farmer
(3,091 Views)
Thanks for the information. Now I found my problem in another point.
There was an error at the beginning of my HTML-file, so I think Teststand couldn't interpret the file.
Now I display my report with the Load method in the Report class of the Teststand API.
Regards
Matthias Langermann
(3,085 Views)
