07-30-2008 07:57 AM
08-04-2008 12:53 AM - edited 08-04-2008 12:54 AM
In your SequenceFile(s) are you trying to call VI's that are now contained in an EXE?
If this is the case then you will no longer be able to use the LabVIEW adaptor and will have to use the Call Executable step type. Also you will not beable to call the individual VI's as before.
If you dont want to leave your VI's as VI's why not create a DLL. Then using the DLL Adaptor you will still beable to call the individual functions as you did when they were VI's
Regards
Ray Farmer
08-09-2008 04:58 AM
