NI TestStand
TestStand - change test limits based on a previous test result.
Hi there.
Is there a way of setting limits during a test? What we want to do is take a measurement, read back the result, and based on this adjust the test limits later on in the test sequence.
TIA
Jim.
LABOR OMNIA VINCIT
(3,433 Views)
You can set the limits to a variable and then modify the variable. Alternatively you can access the limits directly in the Step.Limits container. e.g.:
Step.Limits.Low = Step.Result.Numeric + 1
If you decide to modify the limits in one of the step expressions, be aware that the post expression happens before the status expression, which is where the pass/fail value is determined:
https://www.ni.com/docs/en-US/bundle/teststand/page/step-execution.html
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,355 Views)
I would create a local variable and in the post expression for the step where you take the measurement, add something like Locals.Variable=Step.Result.Numeric
Then, in your later step, make the limit utilize Locals.Variable
(2,800 Views)
