NI TestStand
UserInterface for Teststand with Labview
Hi there,
I want to use a user interface from Teststand with Labview. I have now tested the example user interfaces. Unfortunately, I always have the problem that the memory requirement of Labview is increasing. I am using Teststand 2014 and Labview 2014. Even if I close the completed executions, the problem is not solved.
I'm grateful for all information ...
(2,502 Views)
Usually, I run my TestStand user interface as an executable and then use the run time adapter.  I have sequences that access hundreds of VIs, record thousands of measurements, and haven't really had issues with memory.  Can you give some more detail on the what you're experiencing?
(2,283 Views)
Hi there
Thank you for your response. So far I had tested the user interfaces from the Examples folder. Today I tested the Simple UserInterface and it seems to be better with it. After 200 executions of a sequence, Labview's memory only increased by 2MB.
I will now adapt this user interface to my needs and then continue testing. if I have further questions I will try the forum again.
best regards
(2,201 Views)
