NI TestStand
TestStand development vs deployment environment
Hi all,
How would one detect when a sequence is being run in development environment vs. in deployment environment?
...and it would be better, in this case, if the distinction was not by station ID or anything specific to the computer.
Thank you in advance!
(2,820 Views)
Accepted by T999
If RunState.IsEditor is true, then you're in development.  Otherwise, you're running via some other means, like an operator interface.
(2,765 Views)
Worked great!  Thank you!
(2,754 Views)
