TestStand documentation
is there a chance to print documentations in TestStand, like the VI - documentation in LabVIEW (File => Print => Select VI => VI Documentation) ?
Patrick
(3,757 Views)
Hi Patrick,
do you mean the documentation you wrote in your sequence file?
As far as I know you can't print it out Smiley Sad
gedi
(3,752 Views)
Accepted by patrick1988
There is a documentation tool under the Tools menu item (Tools | Sequence File Documentation ...) This will bring up a dialog so you can select what you items will be put in the document.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,747 Views)
Great, haven't noticed that before...
gedi
(3,743 Views)
gedi,
If you are using TestStand 4.0 or 4.1, you can save your sequence files in XML format and use the Sequence File Viewer to see or print them without the TestStand engine.
The Sequence File Viewer is available as part of the NI TestStand Toolkit for Large Application Development from NI Labs.
Josh W.
Certified TestStand Architect
Formerly blue
(3,726 Views)
