NI TestStand
TestStand does not store results in network drive
Hi all;
 My TestStand does not store results in network drive ( the sequence stores two copies of the report one is locally and the other is in the Network drive ), knowing that the user has access to read/write in the network drive.
(883 Views)
Did you set up 2 result processors?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(848 Views)
