03-13-2006 11:53 AM
03-15-2006 05:01 AM
I have tried to look more into what is causing the problem. It's not a particular stepthats causing the problem. Its the TestReport sequence causing the trouble. I just step through when test failed and unitll execution enters TestReport sequence. Then I pointed out to END with out executiing single step/cleanup. The execution freeze when it tried to enter the main sequence back. So is it some thing to do with parameters information causing trouble???
Any ideas...
Mama007
03-15-2006 05:43 AM
