NI TestStand
TestStand execution freeze at the end on Win XP
I have a problem with TestStandv3.0, when logged in as a operator. TestStand freeze execution at the end of the test. When run step by step, I observed the execution freeze after "TestReport Callback" exactly after the execution of the "Clear Generating Report Msg" in the cleanup of TestReport Callback.
Surprisingly the problem didn't appeared, when logged-in with administrator previlages. I have another machine running same software, but with WIN2000 and same previlages no problem. Current previlages that I had for operator usr is power user, little bit down the administrator. I have also tried fulla cces to NI folder in program files, but in vain.
Has any body faced the same problem or know any solution to this problem
Mama007...
(3,125 Views)
I have tried to look more into what is causing the problem. It's not a particular stepthats causing the problem. Its the TestReport sequence causing the trouble. I just step through when test failed and unitll execution enters TestReport sequence. Then I pointed out to END with out executiing  single step/cleanup. The execution freeze when it tried to enter the main sequence back. So is it some thing to do with parameters information causing trouble???
Any ideas...
Mama007
(3,103 Views)
Hi Mama,
Thanks for your post. It does sound like the problem is related directly to the Administrator rights (or lack of them) for a certain user.
Where are you trying to save your TestReport file? Does the user who is causing the failure have access to the folder where you are trying to save the report?
Best wishes,
Mark
(3,099 Views)
