NI TestStand
TestStand gets hung up after running a test that contains a new thread
TestStand is getting hung up at the end of my test.  I'm trying to kick off a new test thread.  All that thread does is call the TestFunction() in my c++ dll.  I have another function that is called in my main test that is using a function in the same dll called StopTestFunction().  When StopTestFunction is run it sets a global variable to false which should cause the thread to finish since TestFunction() will finish.  Once TestStand gets through the test it simply gets hung up at the end and I have to kill the application with task manager.  Am I doing something wrong when I create the test thread?  I attached an image of the sequence and some code with the functions mentioned above.
(3,210 Views)
Accepted by BCH63
I see two reasons this is happening:
  1.  Your code snipit shows:
    while (doListen = true)
    This is an assignment operation, so this will always be true and this loop will never stop. Comparison would be:
    while (doListen == true)
  2. Even fixing that, this snipit is going to starve the thread:
     number ++;
    This is counting as fast as possible in a loop and will not stop to process other events.
If you're wanting to run something continuously in the background and stop it from a different thread in TestStand, I recommend two things:
  1. Use notifier or other sync object when you need to communicate between threads (like sending a stop notification).
  2. Use Termination Monitor so you can stop the loop without killing the whole process if something goes wrong.
Hope this helps,
Trent
https://www.linkedin.com/in/trentweaver
(3,138 Views)
Thanks for catching the missing ''==" I didn't even realize that I did that.  I will try using a sync object and or Termination Monitor.  I havn't had to use those before, thank you.
(3,100 Views)
