NI TestStand
TestStand open problem
I'm working with TestStand 2010.
Today I opened TS and saw strange window on the top of TS:
This window hides the menu, the edit window and does not allow proper work. I did not find any way to remove it. Even TS repair did not solve this problem.
If I open a sequence, a part of a file is hiding behind this window.
Does anybody know what is that and how solve the problem?
(3,620 Views)
Accepted by Berezka
Try resetting the UI to the default configuration:  With the sequence editor selected, hit 'ALT+V' and then 'R'.
I tried to reproduce the screenshot by changing the monitor resolution with the floating 'Step Settings' and 'Output' windows floating near the top of the screen but I couldn't put it in a state that the picture showed.  Do you remember how the editor got in that state?
Jim
(3,612 Views)
Hi Jim,
Thanks! It worked!
I already uninstalled TS and installed it again - did not help.
I don't know how the editor got in that state. When I closed TS last time (before that window appeared) everything was fine.
Berezka
(3,611 Views)
