TestStand output to log file?
Is there a way to open, write to, and close a log file in TestStand?  I want to be able to name the file, open it, write strings that I create in TestStand, and close the file?  Simple text debug statements such as "Got to test 1", or "First audio reading = 2.548 MV rms".  Surely someone has done this already!
(8,055 Views)
I see a couple options here, unless I'm missing something obvious.
1- Use the activex steps to call into the activex api of a text editor and do it that way.
OR
2- Use create code modules that do it and call those steps from TestStand.  I know that LabVIEW and CVI both have file writing capabilities to any txt file.
You can read in a file using the Property Loader Step.  You can't write using it though.
It's using the call exe commant and writing a test file from the command line.  Interesting!!!!  The only problem here is I don't know how to read from the file using this method.  If you need to read then this might be hard.
Hope this helps,
jigg
CTA, CLA
testeract.com
(8,041 Views)
Hola Rwdale,
I was trying to do exactly the same and I found a CVI library that comes with TS that  has a method to save files, I think they use it to save the documentation files of the sequence files. Hope it helps (it works on my machine)
(8,034 Views)
Good Call!  That dll is actually used for the sequence file documentation.  It's a Tool that gets invoked from the Tools>>Sequence File Documentation option.  In order to write txt files it looks like they made a dll that does all the hard work for you rwdale.
Great Find!!
jigg
CTA, CLA
testeract.com
(8,026 Views)
Looks promising, I'll give it a try.  Thanks for your help.
(8,006 Views)
