10-25-2007 04:06 PM
10-25-2007 04:33 PM
10-25-2007 05:19 PM
Hola Rwdale,
I was trying to do exactly the same and I found a CVI library that comes with TS that has a method to save files, I think they use it to save the documentation files of the sequence files. Hope it helps (it works on my machine)
10-25-2007 05:30 PM
Good Call! That dll is actually used for the sequence file documentation. It's a Tool that gets invoked from the Tools>>Sequence File Documentation option. In order to write txt files it looks like they made a dll that does all the hard work for you rwdale.
Great Find!!
10-26-2007 08:32 AM
