NI TestStand
TestStand testing the return value from dll
As my subject states: I want to test the return value from dll. I would know how to do this in C but this TestStand code is nothing like that.
Here's my logic:
Calling my dll
if ( dll returns -2 )
abort this sequance file
else
continue
Thanks in advance
Michael B.
(3,266 Views)
Have you done a Teststand tutorial already? That helps a lot I think.
I assume you have an C/C++ dll?
Insert step->Tests->Pass/fail test
Select Adapter: C/C++ DLL
Module:module --> browse to dll
select the function (your inputs/outputs should show up now...)
You can bind a variable to the output
Data Source (your pass condition)-->Step.Result or your variable  (press the f(x) to browse)
opt1: return variable != -2
opt2: return variable == -2
Properties->Post Actions->
opt1: On Fail: Terminate Execution (more neat one, it terminates on false)
opt2: On Pass: Terminate Execution
(3,253 Views)
