NI TestStand
TestStandModelReportOptions.ini in teststand 2012?
I've just upgraded from Teststand 2010 to 2012.  We've always had our teststand configuration directory pointing to a directory under our source control tree.  In this directory, teststand used to store changes to the report configuration to a file called TestStandModelReportOptions.ini.  This does not appear to be the case any longer with 2012.  What file is it storing the report configuration to?  Is there a way to force it to the old behavior (storing in configuration directory defined in Configure/Station Options/Preferences/Configuration Directory)?
David J.
(3,172 Views)
Accepted by david_jenkinson
The report configuration(s) (and database, and any other result processor configurations) are now stored in <teststand configuration directory>\ModelPlugins\ResultProcessing.cfg.
Thus, it is still under the configuration directory location you specify, just in a subfolder.
(3,170 Views)
