NI TestStand
TestStatnd operatore Interface does not close properly
Hi
I am using LabVIEW 8.2 and TestStand 3.5. I use the default Operatore Interface (full featured) provided by NI. The TestExec.exe does not close properly when I exit the application. Everytime the process is running in windows. I had to use Windows Task Manager to kill the TestExec.exe manaully.
Is there a fix for this?
Thx
Abdulla
(3,694 Views)
Do you start any new executions either from within your sequences or from within a step that you are not closing properly?
Regards
Ray Farmer
Regards
Ray Farmer
(3,688 Views)
There could be some execution still running. Check the execution list and see whether it is " Executions[0]". If not there could be some there is some execution still running.
(3,684 Views)
I found the reason, actually in station options. debug options / warning dialogs are enabled for memory leak. which was showing a warning dialog when engine shuts down. I disabled it, it works.
Thanks for your comments Gentlemen
Abdulla
(3,672 Views)
