My test station need to test two UUT not at the same time ,Two UUT means two serial Number need to scan, and then test each UUT after scan action . The two UUT are the same PCBA,all the test items are the same. So the sequence file is same. But how to realize it in TestStand ? Can you give me a simple example for that ? Thanks so much !
