how to Test two UUT not at the same time??
My test station need to test two UUT not at the same time ,Two UUT means two serial Number need to scan, and then test  each UUT after scan action . The two UUT are the same PCBA,all the test items are the same. So the sequence file is same. But how to realize it in TestStand ? Can you give me a simple example for that ? Thanks so much !
(3,141 Views)
Have a look at the process model options of TestStand. For your task I would  use the batch model. If I remember correctly there are also some examples delivered with Teststand. Search for MultiUUT and Processmodell in the examples directory of your Teststand installation.
(3,128 Views)
