Teststand 2014 freezing when pressing "module"
Hello everyone,
I'm having trouble working with TestStand 2014, loading module.
First of all, I want to make clear that I have all modules placed in the right folders, and I'm using latest versions for TestStand and Labview 2014/2015 (32 bit).
The problem started when i tried to use the "Call executable" function, to call a python file(v3.6). That broke up my TestStand and every other sequence that I have.
Please see the pictures below.
Also I would like to see what other solution i have, before i reinstall everything 😓.
Message 1 of 18
(970 Views)
Teling from the pictures you posted, TestStand is not able to connect to LabVIEW anymore.
I guess you have tried rebooting the PC 😉
Guess you are working on a development machine, so I'd check if LabVIEW itself starts / if the installation is ok
Next you might want to open the SequenceEditor and check the LabVIEW adapter settings
If this are ok, create a new SequenceFile put in any new step with the LabVIEW Adapter, check if that works
Message 2 of 18
(964 Views)
So, i created a new file and i tried to put my project in it, the same issue. This is the company project, which I worked with other sequences until i this one. Also i tried running the "repair" tool from NI package manager and it got this error:
• The repair operation was not successful due to missing distribution source, user cancellation, or MSI failure. Ensure the source location is accessible or try rebooting and restarting the repair operation. Error code: 1620
Message 3 of 18
(958 Views)
In order to be better able to help you, we shoul clarify the wording a bit
Is that: you created a new SequenceFile? What are you referring to as "my project" (.tpj, .lvprj, ?)?
What exactly did you try to repair?
Message 4 of 18
(950 Views)
I created a new SequenceFile, where i inserted a new step named "Action" and i tried to use a VI from the project to load it.
I tried to repair TestSTand, see picture below.
Message 5 of 18
(947 Views)
What do the LabVIEW Adapter Settings on your machine look like? Menu-> Configure-> Adapters-> LabVIEW
Is LabVIEW working standalone without TestStand? Does opening the VI in question directly in LV work? Is it possble to execute?
IMHO, you get this error because yur TestStand Version is quite old and as such it is NOT installed using NIPM.
You should be able to "repair" the installation using the Windows Control Panel ->  Software (or whatever it is called these days)
Yet I recommend to execute the steps mentioned above BEFORE repairing. Don't panic!
Message 6 of 18
(936 Views)
These are the adapter settings
Also Labview is working alone, and i can run VI's, open projects.
Message 7 of 18
(933 Views)
Ok, this is good news so far!
What I don't understand yet is, why calling a Python module using a Call Executable Step should screw up the LabVIEW Adapter.
Does it happen to use the TestStand API to configure stuff?
Just to make it clear: you are using the Call Executable due to the lack of Python support in your old TS & LV versions, right?
Message 8 of 18
(921 Views)
I tried using a Python script to verfiy a firmware for a DUT.
I don't know if i am using a TestStand API, but i use python because the TS2014 doesn't have a python enviroment like TS2023.
Message 9 of 18
(917 Views)
One last thing before repairing/ re-installing....
Change the LabVIEW adapter to Runtime, close and restart TestStand and after this switch back to Development Environment to re-chcek
Small hope but worth a try
Message 10 of 18
(903 Views)
