NI TestStand
Teststand Freezes when using swithing feature
So i have a problem when using the swithing feature built on the step.
the first time i execute my sequence everything switches normallly...
the second time i try to run the sequence it freezes teststand.
i have notice than when i run my sequence. i can see on NI TRACE  the following:
niSE_opensession
niSE_connect(routex)
nise_disconnect.
but after the sequence is over. the niSE sesion is not close. does that have something to do with TestStand Freezing?
If not have you run into this issues before?
CLAD, CTD
(5,649 Views)
What version of NISE and TS are you using?
Can you provide a simple example sequence which creates the issue on your machine?
What do you mean by "freeze"? How long did you wait until terminating? Does terminate work at all? How do you stop execution otherwise?
Norbert
Norbert
Expert: Geometry
(5,624 Views)
TestStand will just crash
after the sequence finish and i try to start a new single pass sequence it "freezes"
windows dialog program not responding will appear.
i am using TS 2013 and switch exectuvie 3.6
CLAD, CTD
(5,616 Views)
Hm, i cannot see a source of the issue in the provided sequence file.
What if you first disconnect the route "UUT1_No_load & Power" before calling Disconnect All?
As you configured the connection to "manual", this is definetly the safe way to do it......
On the other hand, it could be an issue with the NISE configuration including the IVI settings. Are you sure that this approach works e.g. in LV?
I somehow doubt that the issue is connected to TS.....
Norbert
Norbert
Expert: Geometry
(5,612 Views)
apparently this a known issue with pickering drivers and their switching matrixes.
the NI switch executive close sesion.VI  will hang and never close. thats whay it is forcing a close. it might hang on an infinite loop.
a solution coud be downgrade to visa 5.1 drivers.
this is one of the other reasons to buy NI products 🙂
CLAD, CTD
(5,602 Views)
Accepted by buton
i contacted pickering.... they got me new drivers
Pickering response :
This sounds like the problem that first came up when NI Visa was changed, version 5.2 or greater I believe. At any rate, I would first try installing the latest version of the Pickering IVI driver.
http://downloads.pickeringtest.info/downloads/drivers/IVI/pi40iv_4.10.1.exe
i installed them and it works now.....
CLAD, CTD
(5,601 Views)
