NI TestStand
Teststand Login prompt
Whenever i launch test stand sequence editor, test stand will pop up login window with username as administrator and empty Password. I need to select ok, and then it launches. Can we disable this login prompt? I am currently trying to automate a sequence call and this pop up is troubling me. Any help would be appreciated.
(1,205 Views)
Accepted by topic author GirishVrishab
The TestStand Engine always needs a user context.
You can use the windows user for log on (provided it is added as a user with the according privileges)
What do you mean by automating sequence call? Are you calling TestStand via API to run sequences?
(1,200 Views)
Thanks for the response. Updating station option helped me to skip the prompt.
Basically, I am calling 'TestExec.exe' with sequence name as argument. Its working fine now.
(1,130 Views)
