NI TestStand
Teststand Message Popup full screen
Hi All,
Have searched but cannot find a solution for this, any help greatly appreciated 🙂
LABOR OMNIA VINCIT
(4,551 Views)
Hello!
I don't know the TestStand solution but I think the easiest option is to create that code of message in LabVIEW 🙂 - if you need help in that let me know!
Marcin
Think Dataflow - blog.mtapp.tech
(4,539 Views)
Check options under layout Resize options (Select Resize Text Message which will enable Resize option for your message pop up) then as of now manually i can use resize window and make full screen, you can explore to make full screen automatically.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,475 Views)
Hi PalanivelT
Thank you for your response.
I was already aware of this option in TestStand, unfortunately it does not resolve the issue I have.
LABOR OMNIA VINCIT
(4,469 Views)
It does not look like this is possible, at least on my 1920x1080 monitor.  To get the largest window possible, you could add a large picture, though TestStand will scale down the size to something like 90% of the monitor size.
Pulido Technologies LLC
(4,456 Views)
