Teststand Result Processing
Hello Community,
Using Teststand 2014 32bit
Is there a way to programmatically toggle Result Processing for the Database Enable/Disable checkbox in Teststand?
(4,769 Views)
Accepted by MechUnit
Hi MechUnit,
You can programmatically toggle different report plugins using the DatabaseOptions and ReportOptions callbacks as described in this KnowledgeBase Article.
This only affects the currently running sequence, it does not change what the Result Processing dialog box will show or affect other sequences.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,755 Views)
I believe you can also use this expression from this post:
RunState.Root.Locals.ModelPluginConfiguration.Plugins[<SelectedPluginID>].PluginSpecific.Options.DisableReportGeneration
Pulido Technologies LLC
(4,749 Views)
