04-04-2008 10:26 AM
04-04-2008 10:30 AM - edited 04-04-2008 10:33 AM
04-04-2008 12:00 PM
04-04-2008 12:09 PM
04-04-2008 12:38 PM
04-09-2008 11:40 AM
04-09-2008 01:49 PM
Yes that was the problem. I did a select all and changed all my sequences to XML, but some of the ones at the end never got processed. So the link function works now, but only the first time. Once I click a link to see a subsequence it will show up, but then none of the other links work. However, if I close the viewer, and reopen it, and try one of the links that didnt work, now it will work fine.
The requirements column is the most important issue that I face before I can begin to use this tool. It would greatly help my collegues to use it, but without access to the requirements, the viewer is not useful. A way to see this would be greatly appreciated.
-April
04-09-2008 02:56 PM
04-09-2008 03:05 PM
Ok, I did find this now, and while at least the information is there, it would be difficult to review the sequences without the column view like it is in Teststand. We are looking to have our test sequences reviewed by outside members, and for them to have to open this every time to see if there is a requirement for that line would be very time consuming. I will not need the use of this tool for a couple of weeks, so if this could be resolved by then it would be a great deal better.
April
04-23-2008 08:34 AM
Aucci
This is regarding the hyperlink issue, I have been trying to reproduce the issue but I could not reproduce the error you mentioned in your post. Can you please post some more details or some sample files that help reproduce this error.
Regards
Prasanna Kumar
