NI TestStand
Teststand Style Sheet for sequences in XML
I don't think I can post any of my sequences for security and proprietary reasons.   Basically what happens is, if one of my sequences has a subsequence, in the viewer, the subsequence is highlighted and can be clicked on.  When I click on one of these links the very first time after opening the sequence in the viewer, it works fine and I can see the subsequence.
Now, if I go to another link in this sequence where either the same subsequence is called again or another subsequence is called, the link does not work, and the error that pops up is, "The Sequence file having the sequence was not found in the same folder as the current file or the file is not in XML format.  Copy the file to the same folder and redo the operation."
For this particular sequence I am looking at, the same subsequence is called multiple times.  Therefore, since I know it can open it correctly the first time in one line, I know I should be able to open it on another line, and there should be no problem with the file not being in the correct folder, or not being in XML format.
Message 11 of 11
(792 Views)
