Teststand equivalent of "Automation Open"
I'm looking through the teststand API, trying to find the equivalent of the labview "automation open" tool, where you point the "automation open" tool to an API dll file, or active x object, and it returns a reference to that.
(3,022 Views)
Accepted by david_jenkinson
The ActiveX adapter can create new objects if you select the "create object" option. This option is only available if you select an ActiveX server and class which contains an externally  accessable constructor.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,008 Views)
