NI TestStand
Teststand is deploying lavbview 7.1 and not 7.1.1
I can make an installer in Labview 7.1.1 and this installs and works on a "clean" machine. I make a Teststand installer and install this on the target machine I get a message.
"Executable version (7.1.1) doesn't match resource file (7.1). Check your configuration"
The labview application now displays the same message when it is launched. I then reinstall the application and both teststand and the application now work.
I guess the version of labview deployed by teststand is wrong.
(I'm using the simple labview "teststand operator Interface")
(4,321 Views)
Billy,
You are correct, there is a version problem.  In the TestStand directory there is a file:
Redist\lvruntimeeng71.msm
TestStand 3.1 ships the 7.1 version because 7.1.1 was not released when TestStand 3.1 released.
When you upgraded LabVIEW to 7.1.1, the LabVIEW file is updated but the TestStand file is not.
You can fix it by installing LabVIEW 7.1.1 renaming TestStand 3.1\Redist\lvruntimeeng71.msm
and then copying LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to TestStand 3.1\Redist\lvruntimeeng71.msm
Note that the file names are different because TestStand supports installing several LabVIEW runtime engines.  As you have discovered the LabVIEW 7.1.1 runtime engine can not co-exit with the LabVIEW 7.1 runtime engine.
-Rick Francis
(4,301 Views)
Rick,
I am having a similiar problem.  I get the same error message when I try opening Digital Waveform Editor.  Is the solution the same?  If it is the same, what do you rename TestStand 3.1\Redist\lvruntimeeng71.msm file to?  And do you copy 7.1LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to replace TestStand 3.1\Redist\lvruntimeeng71.msm or just put it with it?
Brian
(4,208 Views)
Brian,
I suspect it is the same underlying problem, I suggested renaming the TestStand 3.1\Redist\lvruntimeeng71.msm file in case you ever need to have the 7.1.0 RTE.  A good file name would be lvruntimeeng710.msm.  Once the file is renamed copy LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to TestStand 3.1\Redist\lvruntimeeng71.msm and rebuild the installer that included the TestStand engine.   The new installer will include version 7.1.1 of the LabVIEW runtime engine.   Uninstall the old installer and install the new installer.   If the problem persists, post again and we can work on it further.
-Rick Francis
(4,200 Views)
How do you "rebuild the installer that included the TestStand engine" and "Uninstall the old installer and install the new installer"?
Brian
(4,175 Views)
Brain,
The original poster did not have errors on their development system.   They created an installer using the deployment utility and installed it on another system and then they saw errors.  If you are seeing this error on the development system then it is from a different cause.    You may want to start another thread and include the  details of how to reproduce the error.
-Rick
(4,156 Views)
