NI TestStand
prototype conflict dialog
Every so often I get a prototype conflict error on a step using the LV module adapter to call a vi. When I go to specify module I get the prototype conflict dialog telling me the prototype has changed. When I look at the vi it doesn't show any changes and the date in explorer shows that it hasn't been re-saved. What's going on here? I have dozens of these steps in many subsequences and it it very annoying to have to go and update all of them.Smiley Mad Please help.Smiley Sad
kph
(3,012 Views)
kph,
If you run the sequence, do you see any problems related to passing the data between TestStand and the VI?  I am assuming that the prototype you see is exactly the same when TestStand asks you to reload the prototype.  It is possible that TestStand may be finding different versions of the VI on you system due to your search directories.  If you have multiple copies of the VI, TestStand may find different version of the VI than you think it is loading.  This is especially true if you have a network drive that may be changing.  You may want to create a test VI with an absolute path to test this theory.
Which versions of TestStand and LabVIEW are you using?
Let me know if you find any more information.
Tyler
(2,990 Views)
