NI TestStand
Teststand step to call a new instance of Teststand environment
I'm trying to create a troubleshooting step and I would like this step to be able to open a new instance of the Test Stand environment. If the troubleshooting step is encountered, i would want the current sequence to pause execution, open a new Test Stand sequence that will allow the engineer to perform troubleshooting steps from a parallel TestStand window, and when the troubleshooting test stand environment is closed to return to the calling sequence.
[DL]
(3,096 Views)
Accepted by DanielJL
Hello Daniel,
I think your best bet would be to just have the steps break on failure so you can then troubleshoot from within TestStand. If you open a new instance of TestStand you will not really be able to troubleshoot the sequence you just ran, it will be troubleshooting a new sequence.
Best Regards,
Adam G
Applications Engineer
(3,078 Views)
