NI TestStand
The .NET method cannnot be accessed
I try to access dll .NET method    int myMethod ( string, string, string , ref object) and TestStand does not success to this accession.
I don't understand cause I call this with Parameters that have same type and ObjectReference corresponding to ref Object in the method
(3,797 Views)
What errors are you getting? If you attach the visual studio debugger and attempt to step into the code do you see your code being called?
(3,748 Views)
Accepted by niva
Its done. TestStand not recognized .Net Object from Dll return method.
(3,731 Views)
