The Python file include "import xxx", but can't be found the function when be called by TestStand
I want to use the serial COM, define the function in the Python, as below:
import serial
def comsendlist(p=[]):
ser = serial.Serial("COM5", 115200, timeout=None)
ser.write(p)
ser.close()
return 0
l1 = [0x67,0x65]
comsendlist(l1)
but when use the TestStand call the Python,but can not find the founction "comsendlist",
Is it because "import" is used in Python files?
How to solve this problem?
(2,182 Views)
I don't have this isses with teststand 2020 by your code.
(2,028 Views)
Thank you for your reply.
This is the complete code.
import serial
def comsendtuple(p=()):
    len1 = len(p)
    for i in p:
        ser.write(i)
    ser.close()
    return 0
    ser.write(p)
    ser.close()
    return 0
# 字符g
l1 = [0x67,0x65]
t1 = ([0x67],[0x32],[0x33])
print(type(l1))
print(type(t1))
comsendlist(l1)
comsendtuple(t1)
Please try again.
I always have this problem here. I thought it was caused by using the keyword "import XXX"
(2,022 Views)
Accepted by Jmknode77
It seems only interpreter the module code in python even using  if __name__ == "__main__":
Teststand seems can only interpreter the clear code.
So, only keep module code like below pic.
Ricky
(2,015 Views)
After deleting useless statements and comments and reformatting the file, I found that functions can be detected in Teststand. Thank you very much.
(2,006 Views)
