NI TestStand
The application failed to initialize properly 0xc0000142.
After several power cycles and USB reconnects, MAX seems to have figured it out.
Message 11 of 15
(1,981 Views)
Jed,
I'm sorry to hear that it was giving you some trouble, but glad that it seems to have been resolved.  Thanks for posting your updates!
Message 12 of 15
(1,970 Views)
Message 13 of 15
(1,284 Views)
I a glad that you have figured out the solution to your problem but I want to further elaborate the solution regarding 0xc0000142 to some people who might not have the same reason to get this problem. The solution to this problem is to do a clean reboot and disable non windows services and startup programs. By doing this, this problem will go away for that moment and time. Now the next steps that you need to carry out is to see what were the most recent installed programs on your system since this error is due to a corrupt program. When you find the culprit just delete it or if possible find a patch for that problem and you are good to go.
Message 14 of 15
(1,257 Views)
The 0xc0000142 error is a incredibly disturbing and common error which affects a range of core Windows applications. Typically considered in Windows Vista, it has additionally been recorded as displaying in XP and Windows 7. The error typically says some thing similar to “<> failed to initialize correct (0xc0000142)
Message 15 of 15
(864 Views)
