NI TestStand
Time Format ISO8601
I have to format a time in ISO8601
It should look like: YYYY-MM-DDThh:mm:ssTZD (1997-07-16T19:20:30+01:00)
I am able to format it to UTC without the TZD (Time Zone Designator)
In Germany there is +01.00
but now we have summertime +1h so it is equal GMT +00:00
Is there a way to get the TZD in TestStand
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 1 of 10
(7,762 Views)
Hi Jürgen,
maybe this helps:
Accessing Windows Time Zone Information Through LabVIEW
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
Message 2 of 10
(7,747 Views)
Juergen,
Another reason why you should use LabVIEW rather than that C "what's it stuff"  Smiley Very Happy
Regards
Ray Farmer
Message 3 of 10
(7,743 Views)
Hi Ray,
It seems in this case the LabView Example( Thanks Andreas! ) will not fit all my needs.
In my Post i did a misstake! About adding the summertime
I Said if you push 1+  Then GMT(+1) + Summer(+1) = GMT(+0) Seems i have to go back to primary school
a learn some mathematic fundmentals.
I need a simple function that gives my local time in against UTC.
Example:
If you are in Greenwich, New York, Berlin(Winter), Berlin(Summer) and get your local time at THIS moment
You will get:
Greenwich       10:20:30+00:00
NY                   05:20:30-05:00
Berlin(Winter)  11:20:30+01:00
Berlin(Sum)     12:20:30+02:00
So getting the local time is very simple Teststand Time() will do it!
But now i need to determine should i add +01:00 or +02:00
Juergen
--Signature--
Message 4 of 10
(7,726 Views)
Jürgen,
so you don't want to get the local time, but you need to read out the difference to UTC?
Regards
Andreas Stark
Message 5 of 10
(7,724 Views)
Hi Andreas,
No, I want to get my current local time and the deviation to UTC
Here in Germany it is +1:00 (Winter) +2:00(Summer)
I need an API that should give me +1:00 / +2:00
or if i am in NY -5:00
See this link on chapter 5.3.4.2
http://xml.coverpages.org/ISO-FDIS-8601.pdf
Juergen
--Signature--
Message 6 of 10
(7,711 Views)
The mentioned example shows how to read the bias using Windows' kernel32.dll. The function is GetTimeZoneInformation.
Andreas Stark
Message 7 of 10
(7,707 Views)
Message 8 of 10
(7,675 Views)
I found a bug in the VI for timezones with a positive offset from GMT. The community link is correct, but the vi link points to the old version...
Message 9 of 10
(7,672 Views)
More developement work has been done here and shared as open source project. A very comprehensive set of time zone libraries. You can also find the package via JKI VI Package manager by searching for "Epoch"
https://github.com/LabVIEW-Open-Source/Epoch-Time
Message 10 of 10
(3,141 Views)
