NI TestStand
To change the default test report form
I want to change the form of the default test report.
I want to display only the result value of the sequence related to Test Pass and Fail without displaying the result Done related to Action.
In addition, I wrote the case syntax so that you can select the next step, re-test, and sequence end when you fail the test, but I want to see the final results of the staff.
Please let me know if there is an example file or how to modify it
I hope you're always full of happiness
Thank you.
Message 1 of 1
(796 Views)
