NI TestStand
To pass parameter values to the object reference of action step in sequence file of teststand programatically using C#.
//Initialize the Engine
            EngineClass myEngine = new EngineClass();
            myEngine.LoadTypePaletteFilesEx(TypeConflictHandlerTypes.ConflictHandler_Prompt, 0);
            Step myStep = myEngine.NewStep(AdapterKeyNames.DotNetAdapterKeyname,StepTypes.StepType_Action);
            myStep.Name = "object";
            DotNetModule dotnetmodule = myStep.Module as DotNetModule;
            dotnetmodule.SetAssembly(DotNetModuleAssemblyLocations.DotNetModule_AssemblyLocation_File,@"C:sequence.dll");
            dotnetmodule.ClassName = "CN";
            dotnetmodule.MemberType = DotNetModuleMemberTypes.DotNetMember_GetProperty;
            dotnetmodule.MemberName = "ISI";
mySequence.Locals.NewSubProperty("object", PropertyValueTypes.PropValType_Reference, false, "", 0);
Sequence mySequence = myEngine.NewSequence();
            mySequence.Locals.NewSubProperty(varName, PropertyValueTypes.PropValType_Reference, false, String.Empty, 0);
mySequence.InsertStep(myStep, 0, StepGroups.StepGroup_Main);
            SequenceFile seqFile = myEngine.NewSequenceFile();
            seqFile.InsertSequence(mySequence);
seqFile.Save("C:\\mySeq.seq");
I have done this,dynamically creating a sequence file in teststand programatically through c#.
Problem is
1.I created an action step and object Reference variable for the step, but i am not able to pass  parameter values to the objectReference
2.I am not able to load the sequence in to the main Sequence of the sequence file in the teststand. How can I do these two things.
(3,694 Views)
Hi
I refer my comments to this thread
http://forums.ni.com/ni/board/message?board.id=330&message.id=27047&jump=true
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,677 Views)
I created the object reference variable programatically for action step through c# in teststand sequence file. but i am not able to pass the parameter values to the object reference.How can I do that?
(3,669 Views)
have you ever followed on my Links ?!?!?
If not please jump to this one
http://forums.ni.com/ni/board/message?board.id=330&thread.id=26880
and read the the answer from Mannoch
starting with this words:
Anthony -
Currently, functionality for retrieving the Metadata Token for a class constructor or member is not fully provided in the TestStand .NET Adapter API. The DotNetModule.GetConstructorMetadataToken() and DotNetModule.GetMetadataToken() methods only return the correct Metadata Token when the member/constructor prototypes have already been loaded. Thus, in the case of your code, when you call DotNetModule.GetMetadataToken(), the method is returning -1 because the member prototype for the Step you are referring to has not yet been loaded.
That means have to do a workaround for your stuff.
Juergen
--Signature--
(3,666 Views)
